P15 metadata
I’ve had a p15 in use for about a week, all good. Blacker background, wider/deeper soundstage before placing speakers in the sweet spot, vocals more real for analog and digital sources.
Question: is there a way to enter metadata for each of the zone pictures? Zone A : TT phono , zone B: DAC … Zone E: Int Amp. Given the use of software in the product it should be a no brainer.
Congrats on your new P15. It’s a wonderful product. Bought mine in 2020, and could not be happier.
If you’re trying to rename the outlets on the device display, as far as I know, that is not possible. You could rename them in PowerPlay settings, and after saving, you need to hard restart the device (from the back switch). All the best.
Ah power play thanks Serhan I didn’t think of that. Time for an 8 port switch. I would like to see a stand-alone product…one that doesn’t require the mother-ship to function.
Other than the metadata issue this is money well spent.
Congrats on the new P15! Glad you’re loving it. Yes, sadly there’s no way to rename them to show up as such on the P15’s display.
I keep a piece of paper on top of my P12 that has a list of what is plugged into where on the back. That comes in handy if you want to power a particular piece of gear off or on.
I’ve got a piece of paper too. Was hoping that technology would lend a hand and save a twig, but nooooo. Regardless the music keeps getting better with everything I play. Remember…it’s all about the tunes!
