P15 Power Consumption
I am interested in installing a P15 and would like to know how much power it uses?
I should point out that I switch off my entire system when not in use so I’m not interested in how much power a P15 uses when left on 24/7. I realise turning everything off has a negative impact on sound quality (I used to leave everything switched on and notice the difference) but now that global warming has arrived in earnest and worldwide extreme weather events are common, leaving everything powered on isn’t something I am prepared to do. Anyway, my question is how many watts does the P15 consume for every regenerated watt it outputs?
The specs for the P15 show >85% efficiency at 1500Va.
Thank you. :slight_smile:
