P15 struggles
A few days ago I added a lightly used P15 to my system, and I’m really having a hard time getting it to sound good. I can hear some benefits with detail and expanded sense of space, but everything is sounding really bright and ear fatiguing, and a little flat. I’ve set the waveform to Sine, Low Distortion, used the CleanWave feature a few times, and ended up lowering the voltage all the way to 105v just to mellow the sound a bit (which does help). Input distortion is about 2.9%, and output is .1%. I’ve had the P15 on for 60 hours, and half of those playing music.
My system is a Direcstream DAC, BHK Preamp, BMC CS2 stereo amp, Focal Aria 936s. Previously I was using a Shunyata PS8 Venom/Defender combo, which was causing fewer tonal issues, and might have had a deeper/quieter black, although it was a bit more of a ragged and dirty sound.
I’m looking for any tips, insights or tweaks for how to get the P15 sounding musical and listenable in my system.
Try plugging the Amp directly into the wall and bypass the P15 and see what happens. I run my BHK 300’s out of the wall and the source and pre through the P5. That may improve the dynamics.
That’s right, I was going to suggest the same thing.
There are 2 preamps (external and amp internal) in the system, is this necessary? Shorter signal path is more desirable every time. Every component in the system will add its own signature to the sound and P15 as superior as it is, it added an undesirable footprint. Your system was on a brighter side perhaps to begin with.
There are quite few things one can do to adjust the sound to the way they like, some ways are fairly easy and others are very intrusive, like modifying equipment PSUs.
Anyway, at your own risk, few simple checks, without going into dark.
Check your mains polarity feeding the P15. P15 live wire must be live, otherwise it may not do anything as neutral wire in power plants appears to be pass through.
Mains polarity feeding your downstream equipment. Transformers in theory do not care which input is hot (live) and which is neutral, however swapping these will effect the sound, 100%. It is to do with outer/inner tranny windings. It is not uncommon for manufacturers to wire these randomly. There is a voltmeter check, suggested on one of DIY famous forums that may help to determine if mains polarity is as desired. Voltmeter is connected to chassis of individual (not connected to anything else) equipment and the ground pin of mains socket (ground must be disconnected from the equipment during the test). Then unit is powered on and voltage is noted. The mains (hot and neutral) are reversed and same measurement is taken. Lower voltage is assumed to be the correct polarity. On mine, I recall, measurements were 20V and 50V. It appeared though all my equipment was wired correctly, but one of mains plugs was reversed inside (UK style). Reversed polarity, in my experience, can give thin and lifeless reproduction.
Low level interconnects may need to be revisited.
This can go further, but it may take years of experimenting.
Thanks, I will look into the mains polarity. I think if there is an issue it has to do with the power itself, or how the amp is interacting with the P15.
As for the preamp issue, the CS2 is an integrated amp, but it doesn’t really have a preamp stage, just input switching and an output gain stage that is part of the power amp. I got the BHK in there to help the DS DAC with its lower output, and to help the CS2 with its overly dry sound. I definitely get a much better sound with the external preamp.
Interconnects are all Audioquest Colorado.
Again, I really dig the big soundstage I get with the P15, but in this system it is coming with a lot of added ear fatigue.
Sorry to hear about the ear fatigue, certainly know how it feels - robs lots of listening enjoyment, definitely something is not right. It can be caused by so many things it may be very hard to find the cause, anything from user errors to equipment properties or mismatch. Even room temperature, humidity and even your own mood can have an effect. I don’t have P15, but from reading here, everyone seems to have very positive experience, also at PS, I believe, they spend a good deal of time trying to make power plants to sound neutral and give few multiwave options to optimize to users’ setup and ears.
Quickly checked the specs of DAC (output Z 100R) and CS2 (input Z 50kR), looks ok to me. So perhaps BHK is softening things for you as it has calmer character.
Running thicker gauge multistrand copper cable to speakers will bring more body into sound. Anything silver coated, single solid core or flat strand may sound bright. Worth checking speakers are not out of phase.
I picked up on this tread due to the ear fatigue comment. I too have been struggling with this for a couple months where I never did before. You can see my system set up in my profile, but have a P5 powering my Acoustat Spectra 33’s and pair of REL S/5 subs and a P10 powering everything else. As it turns out my ear fatigue started when I switched my P5 from Multi-wave to Sine. Can’t say how or why this made a difference, but when I switched the P5 back to Multi-wave, my ear fatigue (which also aggravated my tinnitus) immediately improved. Not sure if will make a difference for you, but thought I would share
Thanks. I took your advice, and using Multiwave 1 did help a bit. Still sitting with it to see if the change is enough.
FWIW my Multiwave setting is at 4 and Phase Tune at 2.
@IanB52 did you find a happier place with the P15? I have a new one seasoning in and initially I was not as impressed or happy as I am after a week. About four or five days in the machine turned me into a big fan, and I’ve been playing with it and listening to the system with it having fun new discoveries. I expected it to take a bit of time to “be all it can be” and my expectations were met.
I’m still grappling with the Phase aspects. I’ve done the “Autotune” about ten times and I get an array of different Phase settings. Twice I got a different setting when Autotuning when all the other settings were identical to the previous press of that selection. Some of these sounded pretty good with some material. . . but my gut so far has me staying at “0” phase.
while leaving all equipment on run clean wave for 60 sec doing so improves sq across the board for
me…my new P12 was good from the get go…run clean wave and check your sq after…
Hope this helpd and that your P15 performs beyond your expectations!!
I didn’t have much luck, and eventually sold it to someone who seemed to be satisfied with the way it sounded. Go figure.
I have a Shunyata Triton V3 now, which retains a more natural sound, but trades that for less noise reduction or power stabilization than the P15.
Cool, thanks for the info. I’m glad you’ve found happiness with the Shunyata.Their products haven’t really wowed me ever but I’ve only ever tried the low-priced products.
I’m learning more about how to integrate the P15 and it’s giving me really good sound. I’m just going to leave AutoTune alone.
I do use Clean Wave, though it seems to have less impact on my system than on yours.
I think the Triton+Typhon QR combo is probably on par with the PS Audio Regenerators in terms of cleaning up power, but much more money. The Triton alone is not quite there, although is fairly benign sonically. I supplement mine with two Noise Harvesters.
I’d say for those who don’t have any of the fatigue/weirdness or tonal issues I did, the P15/P20 is a more effective solution.
I am a big fan of Shunyata’s cables. All my power is Alpha NR, and they are excellent.
Thanks. I’m glad we are both enjoying our systems~
Hey Lonson,
I run a 60 second cycle of clean wave…the results to me seem as from going this is good to
okay now this is more like it…mainly I hear the results in the crispness of transient response,
transparency, the fingers on an upright bass as the they work up and down the frets and fingers stroke the strings, same for guitars, attack decay of piano notes…many other similar qualities of sound.
The standard 3 second or so cleanwave doesn’t quite cut it for me. I find 60 seconds worth more to the point.
While not the topic…I don’t use multiwave as it sounds in my system as if I were forcing the gear
as if pushing a wind up toy …analogy may not make sense…wind up toys run best on their own not pushed…with multi wave bass gets bloated mids thicken air decreases…even if multi wave is set to just 1 or 2 the lowest you can go on mw.
Now back to cleanwave perhaps if you are running multiwave …cleaneave may not appear to have
the results you would otherwise hope for.
I do from time to time play with mw …just doesn’t do it for me…
Hope this helps you my friend…
Best wishes
Hopefully this may help
I’ve had a P10 for several years so I’m well acquainted with CleanWave and MultiWave. My pre-amplification and amplification have huge power supplies that are by-passed with capacitance on top of that and that and also tube voltage regulation for both the input and output stages so perhaps that is why CleanWave has less of an impact on the sound. What you hear after CleanWave I seem to hear before and after CleanWave, with just a bit more of a focus in sound immediately after CleanWave.
I go back and forth on MultiWave using it at either 1 or 2 or using SineWave, and always using High Regulation. This is true so far of the P15 and is true of the P10 (used now in a headphone system).
I’m actually happy 9 days in on the P15 now. Just don’t quite understand AutoTune and will just leave it alone until I have to move the system, which I hope I don’t have to, or if I make major changes to the system, which is unlikely as I love all the components I have and the way the system sounds overall.
As for me the reason I am using auto tune is that thd varies widely from 2 - 4.9 % thd,
and rather playing around with these settings I just rather let my P12 figure it out…
Still amazed with the improvements my new P12 has made over my previous P5
Hi Lonson,
Why ‘high regulation’ instead of the recommended ‘low distortion’?
I have a P10 and adjust it for the lowest output distortion and sound. I adjust phase +3 to match my incoming power, low distortion and MW6. My system sounds identical with SW or MW at any setting but the display reports lower output distortion with MW+6.
