The UK and EU has a vertically integrated electricity supply code with almost 100 years of legislation. Read at your leisure, plus the associated Regulations etc. at www.legislation.gov.uk (search electricity supply) and then search the EU legislation.
I have not referred to this many times, once or twice, and it’s not a claim.
I have never suggested PowerPlants are unnecessary. If I thought that, I would not have bought one.
When I had a regenerator, it told me my voltage rarely moved by more than ±0.5v.
I’ve associated the benefit of mains regeneration with the problem of poor mains (impedance, voltage swing, noise) on transformers, resulting in hum, which we don’t like.
There is an article on this published only a few days ago, in HiFi News, by Jim Lesurf, an audio engineer and Senior Lecturer in Physics and Electronics at St Andrew’s University. He makes the point that there are now better transformers and switch mode power supplies. Here is an extract.
Having not changed my hifi for over a decade, I bought a Linn switch mode powered amplifier and soon bought an Isotek Evo3 mains conditioner (their most popular product).
I then experimented with valve amplifiers and then a few conventional transformer-based amplifiers. During that period I used a PS Audio Power Regenerator.
I then switched to a Devialet switch mode powered hybrid amplifier. I found the regenerator made more noise that the rest of the system, so removed it and then sold it. (The regenerator hummed but the rest of the system is dead quiet, there is nothing audible until you press play.)
For a while all the audio was just plugged into the wall, but I did a home trial of a Shunyata power cable and that alone made a significant difference - wall to Devialet. I bought three and their Venom unit, which is a very expensive mains block that does little more than provide more sockets, some filtering and component isolation. A few weeks ago I borrowed a Shunyata Hydra Alpha A10 and that made a significant difference, so I bought it.
So my experience is that I have benefitted from PS Audio power regeneration with transformer-based amplifiers, and mains conditioning with switch mode power amplifiers. The latter, in my experience, benefit significantly from the lowest amount of electrical noise as possible. The Devialet switch mode power supply is universal 50v - 270v so should not and does not seem to suffer from voltage swings or impedance issues.
I have also said I use other types of power supply - 9v batteries and 9v ifi low noise SMPS for media converters and a Continuous Power Supply for a server.
