Hi,
I have been using the P20 for a year now.
To my ears, it does marvels when it come to removing noise floor on my vintage sound system in addition to protecting my equipments.
Today I realized that it has a voltage regulation feature that allows you to control the output voltage on all zones.
I live in Canada and my P20 runs on 120v, however all my conponents (amps, preamps , DAC, trvintage) are made in Japan and require 100v).
Currently, I am using 3 step down tranformers ( Nissyo ndf-1500u) with my P20, which is not ideal at all. I tried to remove them and adjust the output voltage on my P20 but it won’t let me go below 105 volts.
Is there a way around this or is ot not recommended at all to go below 105v. Or maybe it is safe to run Japanese gears with 105v.
Thank you in advance
