I hope the PerfectWaveStreamer is the hardware version with WaveStreamer embedded? Or are we talking about the software solution itself for Mac and Windows?
@thedude Software is my understanding. Runs on your Windows PC/Server…I believe. Is this correct @Gordon?
My guess is PWS is the famous “SilentServer” that would eliminate the need for a Mac or Win computer on the system.
Paul, if you jump ahead to the SS then the email I sent you might work and would not matter that it does not support Mac. I know it runs on Win but maybe it can run on linux? Mac or Win would no longer be in the loop other than storage if desired.
Never hurts to ask.
http://youtu.be/LH5T2Dg4DSw
How about a card that outputs I2S from the PCI bus?
Ramblin’ ramblin’…
