dennis
June 30, 2014, 7:00am
1
WaveStream with no expiration checking is available at:
http://sourceforge.net/projects/wavestreamer/files/Windows/WaveStreamInstall.exe/download
Source code will be posted on http://sourceforge.net/projects/wavestreamer in a few day s when I finished getting the licenses in order.
Dennis
tony22
June 30, 2014, 9:20am
2
Dennis, is this just an expiration-modified version of the last, or is it a newer version? If newer, what should we look for?
dennis
June 30, 2014, 9:22am
3
It just has the expiration date removed. No other changes have been made. I will be posting the source in the next few days.
Dennis
Frode
June 30, 2014, 10:25am
4
I cannot get it to work on my Win7 Home.
It says it is missing a DLL.
dennis
June 30, 2014, 10:53am
5
I’ll look into it. But that was not in the original release.
Dennis
Frode
June 30, 2014, 11:04am
6
Is it testet on Win7?
I can try to wipe the registry for any remains later tonight. I uninstalled previous expired version.
dennis
June 30, 2014, 11:07am
7
I can try to wipe the registry later tonight.
I am running it on windows 7 proffesional.
Frode
June 30, 2014, 11:16am
8
I know that Home has some limitiing issues (eg. RDP). However, I have got previous WS versions running…
I got the same error message as Frode, except in English. Missing MSVCP120.dll. I ran the PSA uninstaller before installing this version. I have never touched the registry. Running Windows 7 Home Premium.
dennis
June 30, 2014, 11:32am
10
Let me look into it, I must have screwed something up.
Dennis
Thanks Dennis. FYI, I was able to get the prior beta version reinstalled (with a new 30-day period, or so it said), by following your instructions at http://www.psaudio.com/forum/latest-ps-audio-news/how-to-get-around-expiration-date-in-wavestream/ Using regedit to delete the Wavestream file did not change the result when I then tried to install the new version.
dennis
June 30, 2014, 12:52pm
12
I think this is fixed. I just uploaded a new version. Please let me know if it works for you.
Dennis
Johno
June 30, 2014, 1:03pm
13
Hi Dennis,
FYI
I get the same error as Frode on win8
I used the uninstaller first then ran regedit to remove completely
installed new programme and got same error
Thanks
John
I got the same error as before Dennis.
Frode
June 30, 2014, 2:47pm
15
Dennis,
Is your machine 32 bit or 64 bit?
Based on this https://answers.unrealengine.com/questions/14088/msvcp120dll-is-missing-from-your-computer.html
my guess is that it has something to do with the WS GUI that probably is built in VS.
dennis
July 1, 2014, 2:52am
16
Frode said
Dennis,
Based on this 'MSVCP120.dll is missing from your computer' - Programming & Scripting - Epic Developer Community Forums
Mine at work is 64 bit, mine at home is 32 bit.
Frode
July 1, 2014, 4:27am
17
Dennis Kerrisk said
Frode said
Dennis,
Could you try a ‘non-developer’ machine at work that does not have VS installed?
dennis
July 1, 2014, 5:28am
18
I just tried it on a clean 32 bit non development machine and it worked ok. Is your machine 32 or 64 bit? Did you try the latest that is 19.4 Megabytes?
Dennis
Frode
July 1, 2014, 5:40am
19
Dennis
My OS is 64 bit.
I will try the new version when arriving from work.
The latest installed with no errors on Win7 Enterprise 64 bit (at work).
Post Note:
But when I started WS it gave the same error.
dennis
July 1, 2014, 5:42am
20
Frode said
Dennis
My OS is 64 bit.
Did it work? Can you run WaveStream.exe? I am starting to think the issue is on 64 bit systems.
Dennis
