Power Plant Multiwave
When viewing the power plant 12, 15, 20 screen on the face of the power plant. When the display says SINE or Multiwave is that the present setting, or is it to select that setting. Not clear on that. thanks.
As far as I can tell and know that IS the setting. Pushing the selection again changes to the other setting.
Thank you
Hey netspecht-2
The display shows the actual mode you regenerator is running.
If screen show sine, then it is running in sine wave mode, multi then it is running multi.
You can switch the modes with your remote by pressing the mw button. The regenerator’s screen will change to the plug icon screen where the third icon from left will display either sine or multi
just underneath the icon
Hope this helps
Thank you
