I just purchased a New Old Stock Power Plant Premier (PPP).
It does make a significant improvement to my system (ARC, Krell and Levinson equipment) enjoying very much.
I have found the output ‘adjustment’ pot on the bottom of my unit. I adjusted to 120v with my Fluke Meter.
My input voltage from Sawnee Power here in Georgia is 124.8. I have found a Service Manual online that says for units:
Serial numbers PPP-7J and earlier.
The procedure in this Service Manual does not let me adjust the input/output Display to Calibrate to match the actuals.
My unit does not adjust voltage up/down by using the Mode up/Down.
Does anyone have a later PPP Service Manual ? Or a procedure that works ?
Thanks,
Bill
Here is the Procedure in the early Service Manual.
With the unit in standby, press the Mode Down, Mode Up and Power Button
(Logo) simultaneously.
The 3-digit display should light up. The logo and buttons should not be backlit.
This tells you that you are in calibration mode.
The first reading on the display is the incoming voltage. To scroll to other
readings, press the Display button. It will scroll through the readings in the
following order:
Input Voltage – Lights On: Input + Volts
Output Voltage – Lights On: Diff + Volts
Input Distortion – Lights On: Input + Dist %
Output Distortion – Lights On: Reduct + Dist %
Start with the Input Voltage Calibration.
a. Make sure the Input + Volts Lights Are On.
b. Use the mode up / down buttons to calibrate the reading until the reading
matches the actual input voltage.
Now Calibrate The Output Voltage.
a. Press the Display button once.
b. Make sure the Diff + Volts Lights Are On.
c. Use the mode up / down buttons to calibrate the reading until the reading
matches the actual output voltage. (NOTE regenerator is not active during
display calibration)
Distortion readings do not normally need calibration, but they can be adjusted the
same way.
But cannot adjust using the Procedure on page 21; the Display Calibration.
I get: these lights for Input Volts.
following order:
I do not get: The Diff light on
You should be able set the input voltage using the tutorial.
The calibration tutorial is for the input voltage only.
You will not see a corresponding change to the output voltage when in calibration mode.
Nor can you adjust the THD in or out.
You can adjust the output voltage in normal operation mode by measuring the output voltage with a Multi Meter and adjusting the trimpot on the bottom of the unit.
We are not sure why the Diff light does not illuminate.
If you cannot get the unit calibrated we are happy to take it in and calibrate for you at no charge.
I have the 230V (GR) version, 2 same size large fans at the bottom. I guess it’s a Rev2. (SN is PPP-B0-…)
In display calibration mode when you switch to Output Voltage, I don’t have the DIFF light on either which makes me think this is an error in the manual (or maybe later/GR versions work differently compared to pre PPP-7P in calib mode). Otherwise the DIFF light is working fine in normal mode and showing the actual delta between input and output voltages.
In calibration mode, you will see very similar voltage numbers for Input and Output voltages because the regen is not working. For input V check, you tap the multimeter to the closest receptacle. For output V check, you tap the meter to one of the ouputs of PPP. You adjust the display to show the same number what you read on the multimeter.
Second part is to adjust the metal trimpot in normal operation mode to the specified voltage the PPP is made for (typically 120, 230, 240). This is higlighted on a blue sticker next to the input socket. Again, you tap the multimeter to one of the outputs of the PPP for this. This adjustment is a bit subjective. You can go with the (nominal) voltage specified by the local utility in your area or with a voltage which better fits to connected equipments if they specified with the same input voltage.
The local utilty specs are nominal values, so it’s normal to see +/- 5% difference on the incoming voltage.
