Power Plant Premier - voltage and thd output
Hi community
It seems that the voltage and thd output of my Power Plant Premier is much lower (voltage) and higher (thd) than the input (see pictures).
Can anyone explain this and does anyone have a solution?
Thank you in advance.
Ya, it’s broken. Happened to mine when I had it. Needed a trip back home. I think the PPP is a pretty unreliable device. Sorry, good luck and hope it can be repaired fairly easily.
It needs a new re-generator, best have your dealer deal with it.
Okay. That’s what I feared :-/ Thanks for the quick replies.
