I use the PS Audio AirLens with the purchased version of BubbleUPnP via Samsung tablet.
At first everything went smoothly, but now I have the following 2 problems:
After “Play” (= play whole album) playback stops after 2 tracks.
After “Play all from here”, playback also stops after 2 tracks.
Which setting is responsible for this?
Thank you in advance for your support.
I don’t have an Airlens, but I find BubbleUPnP to be glitchy sometimes, i.e. stopping in middle of tracks, stopping at the end of a track, or skipping to next track (using Qobuz). Sounds like you always have the stopping issue, is that correct?
I have no idea if it’s related, but I had a variation on the same theme where I could not get Qobuz to play gapless regardless of settings or media player (mconnect, jriver, roon). If Qobuz Connect was an actual thing instead of the topic of endless unfulfilled promises, I likely would have kept the AL I recently demo’d.
Qobuz runs pretty smoothly for me via BubbleUPnP.
It didn’t stop after 2 tracks at first. Only after I tried changing some settings in BubbleUPnP. And now I don’t know how to reset it to the previous state. Maybe delete the app and reinstall it?
I have no problems with gapless playing …
That sounds like a worthy solution. Reset & start over again!
Or you can email their tech support at bubblesoftproducts@gmail.com.
