PS Audio 4.5 preamp
Hello. I have a PS audio 4.5 that never was powered on. I finished replacing all electrolytics with Rubycon Black Gate capacitors. My story begins with a passion on this preamp first listened to in an audio store in Dallas, TX in 1986. So, as I kept flipping the PCB to repair the far left selector switch, blue cover unsnapped. Made by Lorkin (no original part number). Don’t know if a piece was broken but the 2 wafers, plastic shaft and cover are undamaged. After reassembly I find no solid indents? Just a semi-smooth rotation was left $ right full stops.
Is this switch broken? How do I reassemble it. I tried many times but no luck. I understand there is a replacement part from Allied electronics & RS but it only shows a single wafer. Anyone know the part number andd the set-up for the 4 selector indents orientaton. Need help!!!
anthony
This is called a Lorlin switch and they were out of England. To my knowledge, they are no longer manufactured and haven’t been for many, many decades. I wish I had better news.
Most people replace them with a similar rotary selector and instead of PC mounting, figure out how to graft wires from the switch to the PCB. It’s not easy or pretty. Might be time for an upgrade?
Hello Paul:
Thank you for your quick response. I don’t think it is broken, but I can not see how it was indented to the 4 position switch. Was there there another part perhaps lost when it the cover popped off. I was always enjoyed all of your products.
Best regards,
Dr. Anthony
Can you post a picture?
Hello Paul
Here are the photos from your 4.5 preamp. I think it is a 1986 production.The blue inside cover has lettered numbers. I found a small spiral about 1 inch that may be associated with it placed through the plastic shaft holes on its side side??
The switch looks complete except for the shaft. Problem is that even complete, these Lorlin switches went bad over decades. They were, in hindsight, a poor choice we made for building a long term product. Your best bet would be to replace them with a better
switch.
a spring and ball in the white slots in the circular mechanism 2nd pic from the bottom would give indents in the travel (if it hasn’t pinged off somewhere upon opening)?
Hello Joma
Its starting to make sense now. I did find the spring which inserts through the 2 holes. Need to find the ball. I was replacing the electrolytic when it happened. Problem is do a index the switch. The selector switch has to move 4 positions as seen on the face-plate. Any idea how to position the shaft. Thank you
Afraid not, trial error is your (distant) friend I guess…
That would have been OmniSound?
Not sure if this is still helpful, but there was a post on DIYAudio that suggested that these are the parts:
1 Lorlin SWITCH + 1P 12W Mfr’s Part#: PT6434
3 Lorlin PCB SWITCH MECHANISM Mfr’s Part#: PT6422
2 Lorlin PCB 2 POLE 5 WAY Mfr’s Part#: PT602-003
2 Lorlin PCB 1 POLE 12 WAY Mfr’s Part#: PT602-001
Welcome!
I absolutely love these kinds of posts. Fixing or refurbishing or retro-fitting old equipment to keep it going and then having the rare opportunity hear from the old guy @paul who designed the dern thing! This really scratches my tinkering itch - vicariously at least.
Keep it coming!
I think I have solved replacing/repairing a 4.6 with the original Lorlin wafer switches and my 30+ year preamp works wonderfully - this goes to show the build quality of these little gems. I know, Paul, you said hindsight (yada, yada, yada) was a bad choice, but you didn’t know these were made with lots of lead. The new Lorlin switches are lead-free and actually available. If anyone (and speak up) has a unit they want to know how to fix, please post and I’ll tell you how and what part you need. If there is interest, I’ll make a video or post instructions, but wasn’t really that hard. The hardest part was de-soldering the wafer switches and fitting them back in. Other than that it’s straight forward, other than understanding how these Lorlin switches work. My way is a hell of a lot easier than soldering in retro fit rotary switches - believe me.
Thank you so much for sharing the info. You made it easy for me.
I also listened to the 4.5 in a Dallas store in 1986-Omni Sound.
I compared it with my 2.5x as expensive Musical Fidelity MVT preamp, and the PS Audio Preamp made mine sound like a toy. I even remember the piece of music used…Mozart’s Concerto for Two Pianos from the Amadeus soundtrack. The PS preamp sounded spookily close to real pianos, whereas my MVT sounded like the piano was made of plastic rather than wood.
OK, I’ve now replaced all of the Lorlin switches in the preamp and this is getting easier - only downside is sourcing the parts out of the UK typically - maybe I’m just impatient (likely), but I don’t have all minute. Anyone have any recommendations for capacitors? May just go ahead and do a recap while I’m at it.
