Hi,
Is this possible?
Can I use the standard IR controll?
If yes wich firmeware must i have on the bridge?
If not what can i do to let PC away?
Sony Tablets S with Android possible?
Thanks
Unfortunately, one cannot stream directly to the PWD. There needs to be a PC or other piece of equipment in between that turns the stream into PCM data.
Thanks Elk
Ohhh, its very very, bad.
Is it planed do integrated this feature in the bridge / pwd in near future?
I think this is for very much buyers a real no go.
Thanks
krokodil67 said: I think this is for very much buyers a real no go.
Maybe....depends on what you want the PWD to do....
One solution, however, is to use an airport express
http://store.apple.com/us/product/MC414LL/A/airport-express?
and you can stream from a networked device (like an ipod) using an internet radio 'tuner' of your choice directly to the PWD. I use the optical input for this purpose.
Hi David,
thanks.
I´m a W7 user and have a sony tablet s with android.
You know a good unit / app to do this like the apple way?
Thanks and Regards
Willi
@; sorry, but Apple is not mines.
This was the cheapest/most functional approach I could figure out.
Maybe there is a NAS application that will do the same thing - I haven’t checked.
