Does anyone know how to DIY convert PWD2 voltage from 120V to 230V? I have an 120V DAC and using it with a voltage transformer, but I think it’s best to have the correct voltage directly inside the DAC.
I have done a bit of looking inside and reading and I suspect it is quite simple to convert the voltage, but I’d appreciate any feedback or additional info.
In these pics here, I suspect this is a 230V wiring:
http://www.6moons.com/audioreviews/psaudio7/dac_power.jpg
http://www.6moons.com/audioreviews/psaudio7/dac_expansion_inside.jpg
Notice the red jumper wire connecting pin 2 and 3 on the green colour terminal block
In my DAC which is 120V wired I have 2 jumper wires, connecting pin 1 to 3 and pin 2 to 4.
I suspect the conversion 120V to 230V is as simple as taking out the two jumper wires and connecting one wire as in the pictures to pin 2 and 3.
Is anyone able to confirm?
I forgot which ones, but on the wire block with the white, grey, black and brown wires you need to re-configure those too.
A while back I had contact with someone in Russia that does those conversions.
I can email him and ask, but last time I emailed him my email came back.
My email is rmkarman@cfl.rr.com if you want to contact me directly.
