Which fuse is used on DS Sr. 230v?
I am a happy owner of PSAudio Direcstream Sr. My PSAUDIO was purchased to work on 120v. However I had to move another city and needed to change the DS voltage to 230v.
I noticed that the DS 120v has a 1A Slow Blow fuse.
My question is whether I should change the fuse to 500mA after converting to 230v or if I should keep the 1A fuse that came with the unit.
Thank you very much.
I would leave it.
How are you planing to change the voltage to 230v ?
Thanks for your sugestion.
:+1::grinning:
