Quick Aspen FR5 Impression
I’ve been listening to the FR5s for a couple of weeks now, and for a number of reasons, I can confidently say they’re the best investment I’ve made in quite some time. While I consider myself an audiophile, I’m nowhere near the level of expertise of many of you. I just know what sounds good to me, even if I can’t always explain why from a technical standpoint.
From the build quality to the sound performance, the FR5s are, without question, a solid five-star product. What impresses me the most—though I’m not sure if this is technically accurate or just my perception—is what I’d describe as their “presence.” Regardless of the artist, genre, or recording quality, these speakers deliver a depth that brings certain elements, like vocals or instruments, distinctly to the forefront, while others seem to recede naturally into the background.
I may not be explaining this correctly, but it’s something I haven’t experienced in any of my previous systems. I’ve heard both narrow and wide soundstages before, but the sense of depth the FR5s create is something new to me. It also feels like each sound is wrapped in a subtle darkness or silence, which isolates and enhances it, making each element stand out more clearly.
All of this to say—despite my clumsy attempt at describing the experience—they sound fantastic. Unless I find myself chasing after a set of 10s, 20s, or 30s, the FR5s have earned a permanent place in my setup.
Ditto.
I’ve been running my FR5’s to the point where I can confidently say that they have reached the “break in” point. I run them with a sub just to round out the bottom end, but I have tried them without it and, it was nearly as good. They really shine for tight and quick bass impact on recordings that tend to place a bit more emphasis in that area.
I have to wear hearing aids in order to gain better clarity with regards to everything past 1.5k, otherwise, it all comes across as being a bit muffled. That being said, I don’t do critical listening, but I’ve always insisted on clarity and “faithful” reproduction in my system. If I had the space, I would definitely try the FR 10’s. For now, I’m very satisfied with the end results.
I only wish I could adjust more accurately the frequency spectrum in my hearing aids to fine tune them in relation to the speakers.
Don’t know if you are using Roon, but it comes with equalizer options that work well.
OK, so I just pulled my Parasound P6 / A23+ combo that I was driving the FR5’s with and stuck my PSA Strata in mix. Listening to Simply Red via QoBUZ/Roon (Roon Nucleus One to PSA Airlens via WiFi to the Strata via I2s) and its like a heavy fog that I didn’t know was there has been lifted. The high end is open and very bright (but not too bright). Clear, crisp and airy might describe it better. The bottom end is very tight and the stero pair of Rel Subs are meshed better that ever. Kid you not, the hair on my neck just stood up on the vocal harmony of ‘More’ .
