Somehow, I ended up with more gear than fits on my old hand me down rack and have deiced to build myself a new rack. I figured I may as well share the build here as it goes along. I’m not master woodworker, and just do some as a hobby but that might make this more approachable for others.
Pretty basic design that has 4 shelfs. I’m doing 2" walnut for the frame of each shelf and will use two layers of 3/4" MDF doubled up and veneered on both sides for each shelf. I have some nice walnut burl veneer to use, however, I thought 4 burl shelves would be too much so I think I will just do the top and bottom shelves with the burl and will use maple for the middle shelfs. It may be weird, but I’m weird too and have always like walnut and maple together.
The frame is going to have two mitered rectangles with the bottom being 11" for the amplifiers but the top being about 7". I like miters, but was a bit worried about strength with the weight of audio gear, so I added two mortise and tenons in each miter. I’m also going to add a dovetailed spline in maple at each corner. I’m too dumb to even know if anyone does mortise and tenons and splines on the same miter, but I"m just trying to make it as strong as possible so I don’t worry later. I’ll have matching walnut blocks that will go between the two rectangles which I don’t plan to glue in so I could change the hight easily later by swapping blocks if needed. I think I may add them with a big sliding dovetail that slides in from the front or back, but may just do a couple mortise and tenons for a cleaner look.
Here is a shot of the burl I will use. I’m going to use different sections for each shelf so they don’t look like mirrors of each. Once I add finish, the color in this will really come out a ton.
I loved the grain in this board and felt a bit bad cutting it into heavy 2" strips. Took another couple boards too, but this one was particularly nice.
Every time I fill my dust collector with dust I take a photo as a trophy and there is no chance my dog is missing a chance to go out to the trash. Best shop dog in the world. Figured this is just as interesting a shot as one of me flatting the boards. I hate flatting boards, it’s simply something that needs to be done.
Crosscuts mainly went perfectly other than I don’t have a good way to block off lengths of 51 inches to make a repeatable stop. I had to do those long cuts by eye as best I could, which is not where I excel. So… I cheated and those pieces are off camera.
Got the all miters’ mortises cut for the rectangles and did the first dry fitting. With needing to cut 4 mortises for each of the 16 miters, I made myself a little jig which helped. I’ll be honest and say there are a couple that are not dead perfect when I dry fit everything. This came from me not having a way to block off the long length cuts to make them exactly the same lenght like the shorter pieces. I’m trying to decide if I want to try to buy an extended fence so I can pull that off. It would cost me a couple hundred bucks and require me to recut the long lengths a bit shorter and recut their mortises. My wife thinks it looks fine, but… I’m my own hardest critic and I’d like to get it perfect. I guess after clamping and sanding it would look good and maybe even perfect, but I’m not sure I want to risk it as I don’t want any gaps after glue up.
Might be a week or two before the next update. I want to order some new veneer glue and am tempted to get a vacuum bag setup for veneering and doing bent laminations in the future. It’s a bit funny, I’ll tell myself I’m saving money building something over buying something, then I will talk myself into fancy tools and materials and probably not save a ton of money in the end. At least with audio gear, I can point to something with a giant price tag and still tell myself I saved some money.
