Roon ARC made easy
For those of you who do not want to open port forwarding or don’t know how, here is an easy way.
its an easy and free way to set up a vpn. You can only have one vpn on a mobile device (at least apple is that way) so if you have a vpn you are out of luck.
But if you dont, install the app, login with SSO from google or what ever service you use. Install on your Roon Core (it works with most) login with SSO there, and they connect.
Coincidentally I just posted the Tailscale solution on another thread. Been using it for quite some time now, never fails. My roon server is on a Starlink connection, that is impossible to configure the traditional way. Tailscale simply does not care.
