Is there any sonic benefit with running these through my power regenerator or should I just plug them into the wall.
IMO, Router yes. If the the Rock server is directly feeding your DAC then also yes.
Should be easy to try with and without connecting them to a PP and hear for yourself in your system.
Thanks for the reply. The NUC is connected to the router.
Personally, purely from a SQ viewpoint, I don’t think the PP would make much of a difference to the NUC.
My Roon Rock Server is powered by an LPS out of a P5. If you have an outlet use it. All of my sources are fed by the P5. The BHK 300’s are out of a wall.
Which LPS do you use?
HDPlex 200W
