I’ve used a universal remote for my soundbar before but just found out you can also use your tv remote to control it? Tips please! And if you have other tricks in maximizing the use of soundbar, it would be appreciated. Thanks!
It could depend on the brand of soundbar you have but as detailed here, generally what you’d have to do is make sure that there is a compatible connection (typically HDMI), connect both devices, turn them on and adjust the settings.
