Speaker Width & Volume
I recently moved my speakers about 12 inches wider apart, and I find that I’m turning up the volume a few notches higher when listening. Is my mind playing tricks on me, or is this a well known effect of speaker placement?!
Before and after photos:
where did you find the audio rack? looks nice
Not your imagination. Center fill can be changed by just a foot of extra distance between your speakers. I’ve observed the same. Inching up the volume is compensation for loss of center fill I believe.
It’s a Canadian company called Foundation Audio :+1:
If you really want to hear what your speakers can do, try this.
Thanks. My problem is I have a pretty small apartment here in Hong Kong, and my listening room is L shaped, so I’ve always had a hard time following standard speaker placement guides.
I think I’ve settled on a decent setup for now, I was just a bit surprised that I was losing volume with the speakers wider apart.
