Sprout 100 volume level - how to tell you are at max?
Hello, just a quick question… How can we tell that we have the Sprout 100 at max level? Not that I plan to have it at that level. :slight_smile:
I know when you are at volume = 0 the LED indicator dims out. How about at volume = max? I couldn’t find anything in the user manual…
Thanks in advance
If I’m not mistaken, when it’s set to max volume, the LED will stop flashing. Essentially letting you know the volume is not changing anymore.
Hello Jamesh, I see ok… i’ll look out for that. Thanks!
