How to check if Sprout 100 remote control functions? Does the light need to shine when a function is asked?
Welcome to the community @iteco
Someone with better knowledge of the sprout than myself would give you an answer.
Welcome, @iteco !
Unfortunately I also do not know.
I have the Sprout100 and its remote. When you press a button on the remote, the little light on the Sprout itself lights or blinks if you are turning up volume etc., No light on the actual Sprout as far as I can tell.
