Sprout100 volume knob flimsy
Hello! I just got a Sprout100 and I’m loving it so much. Paired with Klipsch RP-600M and it sounds just lovely. However I have a question regarding the volume/bass boost/Power knob. It feels a little loose, kind of wobbly, not as tight as the input selector. Is that normal? Should I be concerned even though it’s working just fine?
Thank you.
Hello. The volume on my Sprout 100 is a little wobbly but nothing too excessive. Personally I would not worry about it.
Kindest Regards,
Great news! Mine is the same… Just a little wobbly but wondered why is that… Maybe there’s some design reason since the knob fulfill three functions. Thank you.
That is great news. Just enjoy, it’s a great sounding piece of audio equipment.
