I was thinking of stacking my AirLens on top of my DS MkII (using felt feet of course). Is there any known noise or interference issue that could arise out of such a configuration?
Thanks in advance, Dave
I have my AirLens on the DSD MkII and have not experienced any issues using it with I2S, a PST with IS2 (shelf above) and an Auralic Aries G1.1 (shelf above PST) through USB.
Isnt Heat an issue regarding stacking anything on the MkI and MkII ?
None felt to the touch over 10-12 hours.
the heavy thick cases probably trivialize interference
the closeness of cables is probably less immune
answer: test it one way and then the other, they are not Gryphon amps
