I posted something about considering this a while ago. I finally began the real work to make it happen. I have Magnepan 3.7Xs and a pair of DWM bass panels. I asked my dealer if it was possible to stack DWMs. He said, “Yes, it can be done.” Right now I have the 3.7Xs being powered by my M1200s and the DWMs are powered by going thru a digital processer and into a S300. The dealer emailed me and said the second set of DWMs had arrived. For one reason or another, I hadn’t completed the stands to stack them. Finally, yesterday, I got started. It’s been 98 degrees in the woodshop so plenty of breaks and water. Here’s what I have so far. The cad picture is what the completed stands will look like to stack the bass panels. The other pictures are the cherry lumber. The picture of the 4 bases are for the 3.7Xs and the bottom of the DWM stand. I’m making new ones for the 3.7Xs because my old 3.7is had a darker cherry stain than the new ones. I made custom cherry stands for them years ago. I’m going to replace them with something that is closer to a color match. Why? Why not. I expect to have this wrapped up in a couple weeks to a month. I’ll report back then on whether it was all worth it.
After a month of playing the system as much as possible, Micheal came out and voiced the room again. It needed very little adjustment from the first time. The room measurements back what I’ve been hearing. Where the system used to roll off around 37hz, it now goes down to about 27hz. For someone who doesn’t have the ceiling height to fit 20.7s, this was a great solution. I’m very happy I did it.
I knew after we finished the basement 10 or 12 years ago that making the finished part 16’ x 44’ was not the best shape for audio. I didn’t realize how bad it was going to be and how long I was going to have to work toward a solution that worked. This seems to be it.
I’m late to the party here, however, fantastic work. They look great. I’m a step or two down from you with 1.7s and two DWM’s but you have inspired me to make some new stands and dress them up. Good thinking. Any chance you will expand on your wiring and the thinking behind your approach? It seems like you have a better understanding of getting the DWM’s integrated than I do.
I can tell you, and you are probably aware of this since you own DWMs, there are two voice coils in each panel. When the wiring was complete, the stack presents the same load to the amp as a single voice coil, 3.4ohms. I saw him measure it both times. Yes, it’s low. Either the coils are in series and the panels parallel or the other way around. The end result is the same. The stack presents the same load as my 3.7Xs do.
Hello David, I am in awe at your woodworking talents. I also appreciate that you listen in a comfortable room, not a sensory deprivation chamber. You have beautifully coordinated other room moldings and cabinetry. And, you have thoughtfully organized the room so it does not look like a machine room, with cables and equipment strewn about the floor. Bravo!
You mentioned low ceiling. Here is an idea I implemented in the basement of a prior house. Instead of putting in a drop ceiling 2" below the wood beams, using a nail gun, my carpenter installed narrow rails 4" up the wooden beams, and put panels up between the beams. That gave me 6+" more height, and exposed beams (which may also helped my acoustics). Prior to installation I had to plan and, in a few cases, shift around ceiling wiring, pipes, duct work and lighting. Along one wall there was a lower soffit, to accommodate some ducts, wires, and a pipe.
When complete I could still access things by tilting panels out, had more headroom, and better acoustics. Also, guests (and we) really appreciated seeing the old, darkened timbers of the house. And, we enjoyed our time in the room more. Years later, our house sold for a little more to people who appreciated the extra height they did not see in other houses. When finished, the initially skeptical carpenter did it in his home.
I know, it is a big, messy project for you at this point. To circle back, enjoy your beautiful carpentry, room, and sound. -JAS in Phila.
Before I listened to mom and got a degree, I completed an apprenticeship to become a journeyman carpenter. I’m glad I’m not doing for a living anymore, but I’ve never regretted what I learned. We live in a modest ranch house, but every room has raised panel wood doors, with natural finishes. Most of the rooms have crown molding and some have chair rail. Again, all finished natural. I’ve attached some pictures of the other end of the room. The library ladder doesn’t actually move but it adds a nice touch. Thanks for your kind words.
As far as raising the ceiling, I only lost 2 or 3 inches putting in the drop ceiling. I thought about drywalling it but feared losing access to utilities. There are a number of cross braces between the floor joists that would prevent me from doing what you’re suggesting. I bet it looked good.
