Static sound while playing 24/96 after upgrade to Sunlight V2 for DSJ
Hi, I just upgrade the firmware to Sunlight V.2 for the DSJ, I realize sometimes it has static sound when I am playing 24/96. So I go back to Sunlight V.1, everything seems fine.
Please tell me it’s the firmware problem not the hardware. Thanks for reading, looking forward to your reply.
Welcome to the community @simon7737
An easy way to find out is to roll back to Sunlight v1 or Windom. If these happen again, then it’s a hardware issue.
While loading the software, please remove all input cables especially LAN.
Thanks for reply, yar, I rolled back to Sunlight V1, everything fine, so I think V2 has some bugs to fix.
Glad things worked out fine!
