Upgraded the software on my DS Junior. Initial problem was that I had to reboot (*Turn the power off twice) to get any sound through our system. Now, I get pops/skips/dropouts when using by Bluesound Vault 2 to stream. Are there issues between Bluesound and the upgrade? Is there a fix? Can I re-install my old software (It was whatever the last one was called and I had no problems upgrading with the only difference is a change from a Cambridge streamer to the Bluesound)?
Thanks
