I dont know i was thinking of making a thread so we can talk anything about tape;
The king of analogue?
litle history could be good, after reading wikipedia it seems tape was invented by Alexander Graham Bell and patented in 1886
then it came the Blattnerphone in 1928, then cassette developed by Philips in 1962? or was reel to reel machines first?
Tape speed acording to wikipedia:
āIn general, the faster the speed, the better the reproduction quality. Higher tape speeds spread the signal longitudinally over more tape area, reducing the effects of dropouts that can be audible from the medium, and noticeably improve high frequency response. Slower tape speeds conserve tape and are useful in applications where sound quality is not critical.ā
So tape speed should be used and depends on what kind of music is recorded;
lets say classical music should be recorded in 30 ips but rock can be enought in 15 ips? and a person just with a guitar singing is 7 ips or a cassette recorder enought?
Why studio master engenieers ont use the highest speed 120 ips? What is dropouts?
I ad also some videos of info on tape mastering problem etc, if you know others videos put them in
Dropouts usually come from physical problems with the tape - either the magnetic coating has flaked off in spots, or a tiny bit of miscellaneous debris has come between the media and the record (or playback) head. Itās not the primary reason for higher tape speeds. Iām sure itās true that the more tape surface you have for a given second of signal, the chance that a physical problem with the coating will be audible may decrease. But in my experience, thatās not the main benefit of higher tape speeds. Being able to spread a given time periodās worth of signal over a greater quantity of magnetic media (tape) results in lower noise and higher frequency limits. Generally speaking, the less tape per second of signal (whether because of speed or physical width of the tape), the lower the fidelity. A half-inch high-speed tape has the potential to be much higher fidelity than a small, slow compact cassette because thereās more magnetic material to record each secondās worth of signal on. Or at least thatās always been my understanding.
Whether genres of musical performances can or should be limited to specific tape speeds borders on a philosophical discussion on the value of different types of music.
Had a Nakamichi 480 for many years. Retired it a bout 12 years ago, and when I tested it out a couple of years ago it needs new belts and other rubber parts. Gave it a middle school wonk who is still playing with it.
Quite the machine.
My topic about tape (R2R) is the sound quality. Iād love to have the patience and funds to further want to afford the hardware and the tapes. I think the limited repertoire of reissues would sound clearly better than even the best LP setups in many, probably most cases.
It would be most interesting for me to hear how different those mostly unmastered (canāt be different) master copies sound compared to the (for good reason) mastered other media (except if they were a flat transfer anyway). But I think the sound quality will be worth the unmastered character with probably also drop outs and other artifacts usually optimized during mastering.
Otherwise those investing the time, money and patience to play the tiny repertoire wouldnāt be so enthusiastic.
the dragon " it was first sold by Nakamichi in 1982 with a recommended retail price of USD $2,499 and discontinued 11 years later in 1993."
but the Nakamichi 1000ZXL āit was introduced by Nakamichi in 1979 with a manufacturer suggested retail price of USD $3,800 and discontinued 5 years later in 1984.ā
anyway you must feel great to have such a legendary cassette deck, both are beautiful like hell
so in the end it really dont matters also if the cassette tape is type 1,2or4 in the end no material can make more sound of a cassette 1+7ā8 in/s (4.76 cm/s if we compare to 7+1ā2 in/s (19.05 cm/s) reel
ps. wonder why or maybe that is why reel to reels never get the idea of making type1,2,3,4 etc kind of reel tape?
ps.2 i have some cassettes that sound better than any other media format (i miss my tape deck, well i guess is time to look for a yard sale
in my poor experience with cassette vs vinyl i feel cassette it has a kind of soft air around the sound the bass is also like soft deep but in vinyl is more like solid bass and refine treble i guess is just a matter of taste well;
i guess reel to reel master tape direct to master tape will sound better but if we record a music grou with the same microphone direct to vinyl and direct to reel maybe is just a matter of taste?
I had a 1000ZXL that I got for a very cheap price at a Miami pawn shop many years ago. After a year of use, I had gotten the Dragon and decided to sell it and got $5000 for it from a guy in Russia through eBay. I offered it at a ridiculous price and this person bought it. No questions asked. The 1000ZXL was amazing but I preferred the Dragonā¦
Everything from tape to digital has its characteristics, but Iām after revealing as much information as possible on a very high level of involved gear. If you go lower you mostly hear artifacts and limitations of each and think this is the characteristic or quality of each (which it is not). But most argument based on this, either for lacking experience because they donāt know better, or intentionally for dogmatic reasons.
Not sure what would sound better when comparing the same music recorded to R2R and direct2disc.
Yes, I think itās safe to say that the development of tape formulation ātypesā was driven by the need to improve as much as possible on a format that had severe physical limits right from the start. Same thing for a lot of the consumer-level noise reduction schemes. While Dolby Labs began tape-hiss noise reduction work before the compact cassette era, it was the cassette that drove continued development of different types of Dolby NR (A, B, C, S, for various tape formulations).
I sold my Dragon just a few years ago. The fellow I sold it to just about cried he was so happy. I felt guilty having a Dragon and not using it. I donāt know why, considering the pile of other unused stuff in the same closet.
