Yesterday I had a session with Edgar focused on the headphone module of the BACCH4Mac Audiophile+ package. The first order of business was creating a BAACH filter specific to headphones. The process is slightly different depending on whether you are planning to use open-back or closed-back headphones. My headphones are open back Sennheiser HD-800s.
The process for open-back models is very similar to creating a filter for loudspeakers. The ear mics are used (without headphones on), the frequency sweeps take place and then head tracking data is collected. Unlike the loudspeaker process where the head movement measured is left and right (approaching collar bone), the headphone filter wants to collect head rotation data. Once complete, headphones are selected from the Babyface as the output and you are good to go.
For closed-back headphone, you do everything you do for open-backs but there is an additional step that involves picking an equalization curve from a panel of values displayed when the BACCH-dSP headphone module is active.
For listening, you have three options. If the Bypass filter/bin is selected, you will hear your headphones just like you did before ever integrating BACCH in your system. The sound is âin your headâ and no BACCH algorithms are applied. The second option is to simply select the filter/bin where you located the headphone filter created earlier. When this is done, some processing is applied that makes you think you are listening to your loudspeakers. The sound doe not appear to be coming from your headphones at all but from you loudspeakers. The sound experience is very similar to listening to your loudspeakers pre-BACCH (without headphones). Finally, there is a 3-D button that, when pressed, provides the added BACCH 3D soundscape enjoyed when listening to your loudspeakers with BACCH. The major difference being that you hear more inner detail when using the headphones.
Typical use cases:
Bypass: I only see using this mode when wanting to compare âwithâ and âwithoutâ BACCH processing. When doing so, Edgar mentioned there is about a 9dB level difference between the Bypass and the headphone filter. To compensate for this, the Bypass filter/bin includes a level adjustment slider.
Headphone Filter (no 3D): This mode allows you to listen to your system at whatever level you want without disturbing others. You will perceive that you are listening to your loudspeakers before BACCH with perhaps more inner detail. This could be useful for any music that doesnât benefit much from BACCH or for comparing to the next mode.
Headphone Filter (with 3D): As youâd expect, this is like the second mode but now with the BACCH magic fully in play. You can listen at whatever level you enjoy without disturbing others and get the full BACCH multi-dimensional effect.
In summary, itâs a great capability albeit pricey at $1000. If you use your headphones regularly and enjoy what BACCH does to your system, itâs a bargain.
