Is it possible to turn off the display when Roon is playing? For example I select an album I want to listen to and want the display to turn off. When I push the dim button it doesn’t work. It actually looks like it turns off and back on immediately.
Welcome, Bryan!
I do not have a Jr. and do not know, but hopefully someone can advise you if there is a trick to getting the screen to stay off.
Bryan saidIs it possible to turn off the display when Roon is playing? For example I select an album I want to listen to and want the display to turn off. When I push the dim button it doesn’t work. It actually looks like it turns off and back on immediately.
Get into the Setup pages by doing a long press. Then go to the “Display Time” menu and set it to 10 seconds.
Dennis
That did it.
Thx
Very neat.
Thanks, Dennis
