USB Cable Decisions - Budget Parameters
I’ve been using a $50 Pangea USB cable for the last few years with my NuWave DSD and I’m considering an upgrade.
I realize @Paul highly recommends Curious cables but those are outside of my budget. I would like to avoid Audioquest because I’m cynical about that company.
What do you recommend for $150?
https://www.thecableco.com/c-usb.html
Been using it for years. A couple of reviewers use it as a standard. About 4 or 5 years ago I read a cable review of year and the reviewer said his preferred cable was some $500 Chord cable, but admitted this $50 cable did the job just as well.
Between your NuWave and what?
Macbook Air with only a base install and Roon Bridge.
I’d suggest a Wireworld Starlight 8 USB 3.0. $100 or so for the .6 meter and $130 or so for the 1M. Killer USB cable.
I second that suggestion.
@kerosene I have Atlas Element USB SC. Paid EUR 129 for the 5 m version. It is a hak of a cable.
I’m leaning toward the Wireworld Starlight 8 USB 3.0.
Some serious shit going on here. These are silver-clad also. I love Wireworld! Not only do they have a unique design that makes sense, they use really good materials. And their performance backs it up.
https://wireworldaudio.com/starlight-8-usb-3-0-digital-audio-cable/
So how is it?
