Peter, Adam, I am not sure if the Mac Mini Conversion Kit will help the SQ but I have ordered it. My thoughts are that even though the ethernet output is isolated, an LPS may help in other ways… I will definitely report back with my findings. Its another inexpensive mod for me since initially, I will power it (12v) with a Condor LPS which I had on the shelf. I am powering my FMC with a Crave PowerPac CRVPP101 (50000 mAh). I was also powering my ethernet switch with the Crave until I found out that I could eliminate the switch. I have a timer set to recharge the Crave automatically at night. Since my whole kit ( speakers, processor, DAC) all use LPS, I figured it would just make sense to convert the Mac Mini as well. Please let me know your thoughts and if you think I am going overboard on this.
The way I think of it there are two ways that electrical interference can get into my DSjr.
The first is via its mains electricity supply. Without internal modification for battery operation this is unavoidable but can be reduced by such things as power regenerators and dedicated mains spurs (I use both). The source of this mains borne interference is all the devices in your home (and nearby) that themselves put electrical noise onto the mains. In this regard a refrigerator, a cellphone charger, a TV and a computer—whether it’s your music server or not—are all essentially doing the same thing. Unless you turn all these other devices fully off (and ask your neighbours to do the same!) the thing to do is to get a good power conditioner/regenerator and plug your DAC into it.
The second is via the music inputs. My approach to this is electrical isolation, also know as galvanic isolation. For me this is TOSlink for digital audio and for computer file-based audio a fibre-optic link (shortly) in my LAN, as close to my DAC as possible, with attention to the power supply of the FMC closer to the DAC. I don’t routinely use USB to get music into my DAC. If I did I’d be looking into a means of optical isolation for that. If I were using I2S I’d want it to be coming from a piece of audiophile equipment in the hope that it paid due attention to preventing interference. (I know nothing about optical isolation for I2S.)
So if the only route for electrical interference from your Mac Mini to your DAC is via the mains then I’d spend my money on a power conditioner/regenerator upgrade and think that upgrading the power supply of your Mac Mini would, indeed, be going overboard.
Well, I received and installed the Uptone Mac Mini Conversion Kit and powered it with my Condor CP498-A LPS. The resulting sound quality really surprised me. It apparently is not about keeping the noise out of the Direct Stream but more about the Mac Mini and how it handles/processes the Data. The low end is now far more detailed and defined, and the overall energy of the system (which was good originally) has increased dramatically. The thing I noted though is a moderate but apparent lowering of the upper mid to high end definition. In my opinion this could be the result of the Condor LPS limitations (it is not designed for Audio). I have emailed Uptone to get their opinion and am considering an alternative LPS to test in order to balance things out. There is no question (to my ears) that replacing the original Mac Mini switching Power Supply with an LPS does change the SQ, even when using ethernet optical isolation to the Bridge. As a footnote, the Mac Mini now runs much cooler, hardly warm at all, and that is after a very strong and very long listening session.
Interesting. Accepting your evidence then there must be a mechanism for this change. First a question. Is there any electrical pathway between your Mac Mini and your streamer other than the mains electricity supply?
Peter, The only other electrical pathway is the ethernet output from the FMC which enters the Mac Mini through an Apple Thunderbolt ethernet adapter and Bridges to the DirectStream Bridge through the ethernet connector on the Mac Mini.
Hi David. I’m curious if you would get better results without the FMC between the modded Mac Mini now that your potential noise sources have diminished. That would take the power supply of the FMC out of the equation. I found that I didn’t like the FMC between my Mac and the DS Sr but did like it between the switch and the Mini. Also, try the dedicated ethernet port of the Mini to the DS Sr as it’s more robust than the thunderbolt adapter and use the thunderbolt adapter to the switch.
I have tried all the variations for the FMC locations and found perhaps subtle changes. And I think we are in agreement Adam, the configuration that seems to work/sound best is:
Main Router -----> remote AC powered FMC -----> fiber -----> local battery powered FMC ----> Mac Mini Thunderbolt adapter into Mac Mini----> Mac internal Dedicated ethernet port ------>DS Sr. (this eliminated the need for an ethernet switch).
I think this will remain as it is, the logic seems to dictate that the Mac Mini SQ also benefits from cleaner ethernet.
The next (hopefully) enhancement will be to replace my stock Condor 12v LPS with an Audiophile class 12v LPS for the Mac Mini. I expect to receive and install it next week. I am hopeful that this new LPS will help to clean up the entire SQ spectrum, especially the upper mid to high detail which seems to be there now but not as up front, and balanced (especially at low volume levels). This was never the case with the original Apple power supply but the original Apple power supply did not provide the overall detail and energy that the Condor LPS now presents to the system.
Please keep in mind that when I converted the Mac Mini to an external LPS, I changed nothing else in the system so there are no variables present here that I can see other than the power to the Mac Mini.
Agreed. I’m wondering which 12V LPS you are going with? There aren’t a ton of 12V LPS with 5+ amps. I’ve looked at the TeraDak Hifi DC-200W and it seems to be a nice unit and reasonably priced at around $250. From there you could go with the Paul Hynes SR-5 which looks to be quite a nice unit. I think it’s going for about $780 (600 GBP) right now. I don’t doubt the Paul Hynes unit is a great piece of kit. I just don’t know if that’s a value proposition for me, honestly. Regardless, it is well reviewed from what I’ve seen. Here’s a review of a SR-5 powering a Mac Mini:
Keep in mind Paul Hynes website is severely lacking. I know he has closed some of his operations and/or sold them off, so I’m not even sure you can get his products anymore. There is some info on his products’ specs and pricing here:
Adam, there are a lot of 12V LPS’s out there and the Paul Hynes does look interesting.
My first choice would be the Uptone LPS2 (to match the conversion kit) but the cost was a bit extreme. I chose a Plixir Elite. It seems to have the build quality and specifications that should make a SQ difference for my system and I found it at a fairly reasonable price point.
Well, I received and connected the Plixir Elite 12V LPS.
I have now listened to the Mac Mini with the stock original switching power supply, my standard Condor LPS, and an audiophile grade LPS. The differences were quite extreme. I am sticking to my original conclusion:
There is no question (to my ears) that replacing the original Mac Mini switching Power Supply with an LPS does change the SQ.
I am breaking the Plixir in but there was an immediate overall improvement that was much better than I expected. I will fill you in with more detail after tonights listening session.
Thanks for the info David! I must say I’m a little bummed that your mods are making a positive impact on the sound. Now I’ll have to address the Mac Mini mod and LPS myself! When will it ever end?
Actually a big part of me hopes the answer to that question is “never!” I do love a good tweak.
A fellow Audiophile and DirectStream owner who is very familiar with my system came over this afternoon to listen to the re-powered Mac Mini. We spent a a considerable time listening to our familiar playlists as well as some new selections. He is in total agreement with me that the difference is positive and quite significant. We could not identify any negative audible impact. We both agreed that the SQ now included better soundstage, more detail, lower noise floor, increased energy, etc…
It’s now my opinion that either my Mac Mini initially had a faulty power supply (which I doubt since the Mac Mini always functioned perfectly prior to the upgrade) or the LPS upgrade does exactly what it is supposed to do.
Adam, I thought it would be a tweak, like a power cable. For me it turned out to be a very nice upgrade much more significant than the FMC. Please share your conclusions if you do the mod.
BTW, the installation of the conversion kit took less than an hour and was not difficult at all.
Collected courage and installed two tp-link mc110cs, 3 meter single mode two way fiber and using the stock power supplies. One in the normal 220v the other one nearby the ds through a passive 50 hz filter socket. Wow, lots of fun. All worked right out of the box. Ds down, powering up the tp’s, connected to the router, which stayed on, and then connected the fibers, a new shielded ethernet cable to the ds and then powering up the ds. All for about 100 euro.
So much fun listening. I have the impression that a lot of aspects got a small definite step better: somewhat blacker, nicer decay of sounds, like chirps, definity better soundstage, tighter bass. Yet a proof that I have not discovered the final boundary how good the ds can be. Check nice dsd like Alison Kraus, Erib Bibb ( cocaine blues) and the not very well known Bottleneck John.
Advise to everybody: save out one outside friday diner with your partner (for the money and the at home quality time), install in ten minutes, start with Babatunde Olantunji, circle of drums, dawn, dsd of course. Shed a tear, open drinks soon and wait what happens.
Enjoy!
Berlin
Edit: in a July 17 post this year, Paul pointed out that nas/ streaming is still inferior sonically to a disctransport. I thought, impossible with a ‘pure’ digital chain from nas to bridge/DS. But this upgrade I describe above made me wonder. Noise comes in all forms, in signal, grounding etcetera. I think that also Ted made a remark somewhere about noisy computers.
