Using banana connectors on your BHK 300
Ok…but how were they placed…they do require certain things for them to sing.
Hopefully a good ways out from wall and sides they like toe in and tilt back.
with my 948s remove anyone
Lacking any of these there goes the sound stage sadly…
Just trying to figure out how they came short…
Best wishes
DavidA
Here’s a Robert Deutsch review of the 936 using Nordost Valhalla speaker cables.
Interesting impressions.
Not the best out there but still incredibly good.
Best wishes
DavidA
good review, makes sense… the 936s have a somewhat dull top end and the Nordost cables lean on the brighter side of neutral
Big Cardas and DH Labs fan here.
I had the same issue with the BFA style banana plugs. I was able to squeeze them slightly with my fingers and with the posts unscrewed slightly they went in. Ideally I would use spades.
@onehorsepony If you like Quadlink you will love the Parsec. The stuff is smooth and not expensive! In a similar price range, the Q10 that david keeps suggesting is hard to beat, transparent but not bright and good bass. You can stop here and be happy for decades… After that you’ll have to jump all the way to Clear Reflection as Cardas suggested.
My final speaker cable setup is GR Research 24 strand diy speaker cable. When terminiting the copper strands merging is too large to completely fit into anything, but at Moon Audio I found Cardas CGMS 9R M Spade and still had strands that I soldered to the outer body of the connector because I didn’t want to cut any strands of CU.
