Using Filters Before P10?
Hi, I just upgraded to P10 from PPP.
I know that using filters before or after the regenerator is not recommended. Actually that was the case so with PPP. Does it still count on P10, too?
The regenerator generates a fresh absolute sine wave from DC, so shouldn’t it be getting rid of all noise that can make upto the unit? or still usage of a filter (maybe a Wall receptacle from Furutech with filtering) would help for a cleaner electric to make it up to P10?
Thanks,
Depends on the filter. If you use one, you want something that does not restrict current. The PSA Soloist and PowerBase are two examples. A high quality wall receptacle also helps.
