WaveStream with no expiration Released.
Dennis Kerrisk said
Frode said
Dennis Kerrisk said I just tried it on a clean 32 bit non development machine and it worked ok. Is your machine 32 or 64 bit? Did you try the latest that is 19.4 Megabytes?
Dennis
My OS is 64 bit.
I will try the new version when arriving from work.
The latest installed with no errors on Win7 Enterprise 64 bit (at work).
Did it work? Can you run WaveStream.exe? I am starting to think the issue is on 64 bit systems.
Dennis
Sorry, check my Post note above.
Mine is also 64 bit. Windows 7 Home Premium.
There is a new version that should fix the problem. It forces the VC runtime to load on 64 bit.
http://sourceforge.net/projects/wavestreamer/files/Windows/WaveStreamInstall.exe/download
Dennis
It installs, but give the same error during startup of WS.
Frode said It installs, but give the same error during startup of WS.
Did you use the one I just posted? Did it install the Run time libraries?
Dennis
Dennis
Yes, it did install the Visual C part and then commenced with concluding the MSI.
I used the link provided in yout last post.
Dennis
Well back to the drawing board.
If you install BOTH the x64 and x86 packages from here:
http://www.microsoft.com/en-gb/download/confirmation.aspx?id=40784
it runs fine. Doesn’t make any sound, but no DLL error messages either.
Peanut Butter said If you install BOTH the x64 and x86 packages from here:
Funny that is exactly what is in the installer exe
Dennis
For some reason the x86 package isn’t getting installed by your installer, at least in the case of a 64-bit OS.
The missing DLL is the one that belongs in the windows\SysWow64 folder.
Peanut Butter said For some reason the x86 package isn't getting installed by your installer, at least in the case of a 64-bit OS.
You did install the on e I posted this morning? Did you get the VS runtime libraty install message?
Dennis
Dennis
Downloaded this morning at 0810 PDT. 19,351,559 bytes. The message was “MSVCP120.dll is missing from your computer”
Peanut Butter said
Dennis Kerrisk said You did install the on e I posted this morning? Did you get the VS runtime libraty install message?
Dennis
Like I said before, back to the drawing board!!
Dennis
Source can be found at :
git clone ssh://dennis_k85@git.code.sf.net/p/wavestreamer/code wavestreamer-code
Dennis
Thanks, Dennis
Now we will see if those clamoring for the source will actually do anything with it.
Should we start taking bets?
Elk said Thanks, Dennis
Yea, I’ll bet a beer that nobody does anything with it. Probably get more takers for eLyric. But neither project is for the faint of heart. Too bad I am not more of a windows guy.
Dennis
Dennis Kerrisk said Too bad I am not more of a windows guy.
It's good, not bad
Unfortunately this is my prediction as well.
There is generally a close relationship between the greatest amount of whining and the least amount of productivity.
I’m not a beta tester, just wanna try Wavestream out, but the program doesn’t run and always say its not compatible with windows…
jazzbug said I'm not a beta tester, just wanna try Wavestream out, but the program doesn't run and always say its not compatible with windows....
Does it install ok?
