Um, no batteries don’t last too long relative to costs. Lithium batteries have improved to 8 years or 100K miles. The rate of charge damages the Lithium and you either charge more gently or decrease the battery life. The tech is stuck at the anode tech and charge rate. This isn’t hidden away unless you don’t want to be well informed about your purchase.
Would you buy an IC car that has the engine replaced in 100K miles? I don’t think so and a lithium battery pack is equally expensive SUBSIDIZED. SS batteries can go where Lithium left off, but a 300 mile range is not adequate and is for fair weather only. The rate of drain to warm the battery reduces the range in cold weather.
Go here for a 2020 battery replacement analysis; How much does a Tesla Model 3 Battery Replacement Cost? | Current Automotive
In summary; “Parts and labor combined, it cost nearly $16,000 to replace this Tesla Model 3’s battery pack.”
The argument is never about full charge performance, for that get the Porsche. It holds battery current drain most consistently full to depleted charge.
A battery is a chemical reaction and temp increases the batteries internal resistance if not compensated for. No way to get around that…same as an IC engines heat waste. It comes with the tech. When we get it too hot, the ANODE tech starts to fail us and heats up, so batteries are a challenge to hold in their ideal range. The world is far from ideal.
Go here for a 2020 assessment of reality so far.
To what degree does temperature impact EV range? | Geotab
We can make electric cars, but outside of pure acceleration they are not an equal replacement for IC engines across all use and range temperatures. We’ll see hydrogen and hybrid style tech allow adjustments to be made based on temps. IC is still viable with hydrogen sourced, same as electric, “fuel” formed off the electric grid. Look at electricity itself…we have several ways to “manufacture” electricity so a amalgam of solutions seems more likely than not.
If you carefully fit electrics difference and understand the true ownership cost down the road (I’m full of puns) and when the rest of society isn’t paying you for your cars true costs, what’s the problem? Electric is just a choice.
We should be arguing the use patterns and not the reality of the tech. The real world has the limitations to use and fit the purchase to the buyer. I still don’t see the public really understanding all this.
Best,
Galen
