I could not find this answer in previous posts. My apologies if it has been answered. I cannot find an adapter that will link the Chromecast 3.5 mm plug to either the USB or toslink input on my Sprout. Can anyone share a source with me? Many thanks!
As long as it’s a Chromecast Audio - the original.
The 3.5 mm plug doubles as a mini toslink port. All you need is a mini toslink cable as posted above.
I’m sorry - I have the original Sprout. Not the Sprout100
I meant the original ChromeCast Audio, as it’s 3.5mm is both analog and mini-toslink.
The newer ChromeCast I believe only have HDMI.
Either Sprout will accept the Toslink signal.
I believe the original Sprout had a co-ax input but not Toslink. You can get a Toslink to co-ax SPDIF adaptor on Amazon for a few bucks.
Now that will work. Thank you!
Happy to help! I have this adapter and it works well, and from a reputable brand.
You will still need a co-ax to Toslink adaptor if you are using an original Sprout, which only has c0-ax and USB digital inputs.
