Your Next Upgrade? (Part 2)
Yes, those three lean in the same direction to my ears as well. System synergy is key.
I’m normally an 11 (with some exceptions that are 12) and I bought 12s…they fit perfectly! My uggs have been 12s.
I wear these around the house during the day, out back on the patio, bringing trash cans up from the street:
https://huckberry.com/store/greys/category/p/64879-the-outdoor-slide
Lounging in the evenings these are my go to:
what a time to be alive….and take that unironically.
If there’s any other ways to identify old men in a virtual space, I don’t know what it might be. :crazy_face: Slippers, high end audio…
Crocs ftw.
No comparison.
Croc in summer and OGG in winter for me. OGG gets worn out much faster. Maybe I’ll try Kipuka, but winter is over here.
Robes - definitely needs exploring.
Robe, slippers, and maybe this, I am still deciding:
I think I may wait until new grinder arrives.
Now we’re talking.
Hmmm…:rofl:
The first phase of downsizing is in place, roughed in.
I think they are the true sweet spot in the Wilson line.
That looks more like going up…the down staircase. :partying_face:
How so, as they provide for a smaller foot print than what they replaced, Genesis Technology V. Then there is the dedicated genesis Technology 400 wpc RMS class A/B servo amp, and dedicated AudioQuest woofer cables.
Well…I guess in your instance it would be a downgrade!
I was thinking more like an integrated amp,cd player and/or streamer and stand mount’s. :grin:
Next step may likely be a solid state integrated amplifier. Stand mounts take up similar floor space to the SabrinaX IME.
For me it is more about weight than dimension…112 lbs each is quite heavy for an older person to move about.
In addition to the usual suspects see if you can find some place to audition the integrated amps from Audia Flight and Norma Audio. Two Italian companies. Also if a hybrid integrated interests you the Modwright model.
I hired furniture movers to bring them into the house, and have them on gliders for positioning until final position is locked in. Regarding my massive stand mounts, they are mounted on Target stands loaded with lead shot and Black Magnum sand blasting grit.
EDIT: BTW: I neglected to add they are displacing speakers that weigh in at 150 pounds each, and the servo amp at 30 pounds. Once set I don’t concern myself with weight as much as my ability to integrate them into my space.
