Your Next Upgrade? (Part 2)
I have three power cords with NCF plugs, and the latest is the pigtail for FB. In my system the last 10% of the deep bass and dark background seemed to take two to three hundred hours more to reach. After my vacation, a few weeks ago, the SQ continued to improve and I contributed it, mostly, to the pigtail break in like my other cords.
The Furutech NCF wall plate/socket took a lot less, but I had new fuses, cable, and others going on at the time too so I was not sure.
But it does not surprise me that in a different system they may break in sooner, or longer.
Great news!!! @jamesh
I don’t have to send my M1200 back!!!
Had an issue with the blue light by the tube area staying on (and the tube itself). Turning the M1200 off and unplugging it for a while didn’t resolve it. But removing and resetting the tube did resolve it. The M1200 now clicks on and off normally!!!
Thanks for letting us know!
Excellent
I had this gut feeling it just needed a “reset”, if that is the proper term. As a bonus, I made an ever so slight change to speaker toe-in and now the system has even more “magic”.
Yes a complete “ctrl alt delete”
Speaker placement remains a tricky item.
I had that happen to one of my M1200s as well. Only happened one time and the amp has functioned normally now for months afterwards.
Just took the first retail delivery of an Auralic Altair G2.2 in the USA a few days ago. So far, so good. An impressive bit of kit for the ask.
That may be my next move once new room is built. Love to hear your impressions and comparisons to any other streamers. Really looking forward to Dirac coming to that platform.
The only other streamer I can meaningfully compare it to is the Altair G1.1 I have in my other system. I have used the G1.1 in my main system and the G2.2 definitely performs on a higher level. But, it’s still breaking in so the final differential is yet to be heard. Compared to the digital reproduction of the Luxman d-08u disc spinner, most aspects of reproduction are very similar. The areas in which the Luxman does noticeably better are matters of soundstage depth and channel separation. Considering the Luxman costs three times the Altair it is rather sobering to consider how steep the costs of increased performance are.
Great to hear! Also, thanks for letting me know the solution. This will be helpful for other folks.
What’s the diff between ALTAIR and Aries? Storage?
Aries is a streamer and can have storage but has no DAC. (I have an Aries G1.1 with 2 gb) Altair also provides a DAC. Here is a link to some info:
I knew the Aries but was not sure what that was. Thanks for the link. I have MKII so will stick with Aries if I persue.
I got mine before the AirLens and it is connected to the MK II with AQ Coffee USB. Still use it for AirPlay and as a server. The AirLens is primary and I use I2S.
The Auralic forum posted this today when someone asked about when it would be forthcoming:
This is a great combo and the certainly sounds better than the Auralic Steamer DACs. The Mrk2 is very good but once you get this streamer feeding it you just realize how good.
Just upgrade to the Syn Galileo USB and this was another step fwd for this combo
Acoustic addition through subtraction of two double sets of drywall that formed a closet. Before and after comparison. The room is now acoustically symmetrical. Prior to the removal the extra walls pulled the center audio stage to the left. However after removing the closet walls the woman in the house sees the opportunity to remove an additional separating wall behind the couch for better room flow. She is also agreeable to reposition closet functionality to the perimeter of the room.
Coming along very nicely, I too like how elimination of the closet opened up he space.
Congrats, less walls more music!
You could also level the floor where was the closet, it should bring a sort of 2 areas, before and after the step, keeping best symmetry on right/left axis of the entire room.
