AT&T has been dead to me since the 80s…
Exactly!
Just say no to thugs!
I ran the test and got a B (1 gb comcast/xfinity isp). All wired (Cat 6) music network. I do experience dropouts. A B isn’t good enough? Think there’s more to it.
Cable is a bit different than Fiber in the fact that your neighbors can effect you bandwidth. Shared along the route. It used to be a big deal, but not sure how much of a factor that is now. Fiber is just better if you can switch. Usually at least the half the price too.
2gb fiber connection to the house and then a Wifi6 Orbi (router plus 4 satellites). 2290.02 download and 2272.19 upload, ping 8.26. Pretty decent speed in the entire house!
My Bufferbloat test score is a “C”. Going to turn off/on router and recheck. Sometimes it helps, like Baldy said.
I think they are truly better.
And I don’t think I’ve heard anyone whos used them say any different, they’re almost always referred to as the best. Very excited
Have been bufferbloated with a ‘C’
But all is well
I can’t tell if they are better or not because you have not specified the camera you used to take the picture or provided documentation of the proper calibration of the camera. Not to mention that you have not provided any details about the lighting in the room or the computer or network/internet resources used to transmit and post the picture here…
I guess I’ll just have to take your word for it.
I’m pretty sure my next larger scale (for me) upgrade will be either the LUMIN U2 or the new Rose RS130. It appears the Rose will be comparably priced, so it’ll come down to sound then features. I like the I2S out of the Rose, and the so called “optical” USB. But the U2 has a dedicated audio USB output that I’m hoping is galvanically isolated.
The Rose has only one OXCO, while the U2 has I think four. This suggests the Rose may be doing a bunch of multiplying and dividing to get the other frequencies. That smells of generating more noise. As does the onboard SSD for buffering. On the one hand a good idea on paper, but if not done well it’s another electrical noise generator.
The Rose does have that great display, but all my equipment is at my 8:00 position. How useful is that for me when I’m controlling everything from an iPad anyway? I also don’t like that it has what seems like a fairly robust video out capability. Just more potential for generated noise for me. I like how the LUMIN is no muss, no fuss, every drop of their effort goes to audio. The proof, however, will be in the listening.
My modem feeds my Innuos server that hosts my Roon Core over about 20m of CAT8 via a basic ZYXEL switch. The server fed my streamer over fibre using the same Netgear 16 port and 2 x SFP that you probably have. At both ends I use standard TPLink media converters. I never had a single skipped track.
I eliminated the switch by coupling the two fibre cables together. The total is about 40m, but not an issue.
Where I did have problems was running Roon core on a QNAP TS-473, which is Roon’s recommended QNAP. I did get skipping tracks, even if infrequently.
My suspicion is there is a problem using Roon Core on a server that is not dedicated to the task and is multi-functional. I don’t think cables, power supplies or switches have anything to do with it.
Could be. Lots of theories out there. I’ve read most of them.
DS MK2, to me, has eliminated the advantage of I2S link. My Summus2 has an I2S output, and I was using AQ Dragon48 hdmi from Summus2 to MK2. But guess what, the Shunyata Omega USB cable just sounded so much superior. I have been using USB ever since.
My streaming goal is simple. If Lumin U2/LHY SW-10 can provide SQ equivalent or better than PST, then I am done! However, if PST is still on top, then there is Aurender N20 further down the list. But I have a feeling Lumin U2 will do the job, because Summus2 with SW-10 is very close to PST already!
One thing that’s favourable about the RS130, is that it has a breaker, instead of a fuse.
Or is it unfavourable, because it can’t be tweaked?
I am really surprised at thee rose130 price. I do love that screen but in the end if the Lumin is a better streamer because the money was not put to screen, I would go with it. I have not heard either so time will tell on that. I would throw in the G2.2 coming out from Aurlic as well. But its 1000 more in price. It does have the clocks, upgraded power supply and now Dirac. Coming out next month as well. Those would be my top 3 all behind the Grimm…but thats a bit more pricey.
It’d be a jump for me to the Auralic, but I do really like that it has Dirac.
