Folks: while changing dip switches I detected a loose piece of material inside my AirLens.
I seem to remember something along this line being discussed with DS MK2.
Any suggestions?
Thanks, Dave
Any suggestions?
Thanks, Dave
Flip it over before operating so you don’t short anything if boards are not conformal coated. Otherwise open it up or return it to remove the FOD.
Opened up the AirLens and found a short, black chassis (?) screw and washer inside.
All quiet now on the eastern front
Dave
Smart to have opened it up and removed the suspect bit. But unfortunate you needed to do so
My wife and other folks around here think that with this audio stuff I have a screw loose.
