I was installing my new analog board and I tipped the DAC on it’s side and this 2" long foil tab fell out from inside the chassis. It doesn’t look real important but just wondering where it goes/what it’s for?
It came off the cover. There should be a few others still attached to the cover.
It should be obvious where it came off of and can easily be reattached.
Ahh…of course :^ / I had put the cover aside. Thanks!
I’d skip reattaching it - the last thing you want it for it to fall into the electronics. The fingers are to make a good contact so that RF doesn’t leak out… The DS doesn’t radiate much so it’s not really much of a problem.
Thanks…I’d already gotten it back on :^ )
