Folks / support : I decided to check for new firmware updates on my AirLens. Once completed I am getting a blinking orange on status LED which seems to indicate that internet connection not available. However, my Roon devices can see the AirLens as audio output device.
I have tried a factory reset, loading bin file via USB but I get immediate blinking orange no matter what I try.
Next idea is to try wi-fi BUT ethernet connect is my greatly preferred method.
I’ve had the same problem - even getting the AirLens to initiate the factory reset process involves a bit of trial and error.
In my case, with Ethernet connected, the unit will typically go straight to blinking orange despite holding the WPS button at startup. When this happens, I’ve found that disconnecting the Ethernet cable and following the factory restart steps usually is effective (sometimes another restart with the Ethernet cable connected while following the reset process does the trick).
I’ve contacted PS Audio Support about this. I’ve been told that they have a software update in the works that will correct the issue.
