Airlens connectivity
I have a chronic, unpredictable problem getting ROON to discover and sometimes hold onto my AIRLENS connection…anyone else share this problem?
If you have not already done so, power down and unplug ALL network related kit in your signal chain, including your router, AirLens and computer or other devices housing music library and/or control software.
Starting with the router and computer, power everything back on up the line ending with your DAC.
Some times the “handshakes” between and among networked devices get corrupted, for lack of a better description, and require a reset.
The challenge is finding which gear is having trouble communicating. So, I take this approach and, more often than not, it usually restores order.
Good luck.
