Airlens.... tied to phone, tied to Qobuz Connect app....how do I UNLINK it ? iPad works
Having Qobuz Connect issue w my Phone and iPad…..
Here is the situation. I have 5GB data per month on my Verizon Samsung phone. Never need any more that that and that’s fine.
Ive been using an iPad to control my Airlens….no problem….
Ive got a Qobuz app on my phone….. when the wife uses the iPad to play tunes on the Airlens, the Qobuz app on my phone shows that its ON and its using data.
The iPad is showing its playing Qobuz, my phone shows its playing the same song.
When I stop the song on the phone, the Airlens stops playing
When I turn off the phone, the Airlens continues to play. When I turn on the phone and access the Qobuz app it again shows its playing and using my phone data.
On the phone, if I stop the song, it stops the song on the Airlens and iPad
I have deleted the Qobuz phone app and then downloaded it again….same thing….
Is it a setting in the phone?
When I see what device Qobuz is streaming to , its the Airlens….
how do I unlink the phone…. for now, Ive deleted the Qobuz phone app. I do use it on trips,
Any suggestions are requested….by the way, the phone setting is to use WiFi for any internet..
Scratching my head on this one….
Thanks for your help
