Is album art supposed to show on screen of the DirectStream when using USB input? Art shows up fine via BII but not with USB and IIRC it showed up using USB on PWD.
Album art on the DS is Bridge only and always has been, including B1 and the PWD.
Thanks for jogging my memory Steve. I seldom used USB, particularly after BII came out. I do remember optical not having it. Once I get my PWD set up in my office I guess I would have figured it out.
No. Artwork comes on the touch screen only with the Bridge, not USB.
It would be a nice feature but I suspect the data just isn’t included in the non-Ethernet streams. Perhaps it’s because the Bridge is a renderer/player and does more processing of the files than occurs when using other interfaces.
