So maybe I’ve completely missed something here (I have searched) but what is the trick to getting album info to display on the DS through the Bridge. I’ve used Roon, & MConnect (Tidal & Minim Server) all to no luck…
Thanks
Thanks
I don’t know what other tricks are needed, but you at least need an SD card plugged in back of the DS (upside down as usual.)
LOL,… OK, I’ve missed something here,… I thought that info was streamed… based on your comment above, that leads me to believe that all of the album pics, metadata, etc must be loaded onto a SD card and left in the back of the DS?? Did I miss this in the manual? I swear I read that thing cover to cover…
Actually rethinking what you just said,… maybe a blank card is used as the temp storage method for the display as it is streamed/loaded?
Johnny saidActually rethinking what you just said,… maybe a blank card is used as the temp storage method for the display as it is streamed/loaded?
Haha,… yep, and just like that I have album pic for what is being played… Thanks for pointing me in the right dir.
