Amp delay while using speakers and speaker amp for my electric guitar
Hello
I am trying to use my hi-fi speakers and amp to play my electric guitar through while jamming over songs from my ipad. Unfortunatley it seems the amp is causing a delay between when I pluck the string and when the sound comes out of the speakers.
I have an emotiva a100 amp and some elac desktop speakers. My DAC is a focusrite audio interface. The music comes from my ipad via spotify to the focusrite which goes to a little mixer I have. The electric guitar signal goes into a seperate channel on the mixer. (I do this so I can have better control over the guitar volume relative to the music since the audio interface has trouble with clipping) then the audio out goes from the mixer to the amp then into my speakers.
I think the amp is the culprit because when I take the signal from the headphone jack on the mixer into some headphones, I dont notice the delay.
I guess I just wanted to confirm that that an amp could cause delay in this situation. Maybe it could be the cheap walmart rca cable I have running from mixer to amp but that seems unlikely to me. Also if it is the amp is there a way to get it to go faster lol.
Thanks for your help :slight_smile:
turned out to be the cheap walmart cable. Guess alot of resistance? Oh well no need to reply :slight_smile:
In the original post, the user said that they were experiencing noticeable delay in the sound when using speakers and amps while playing their electric guitar. They later realized that the root cause of this problem was the cheap RCA cables. When they connected and listened to the mixer’s headphone output, they no longer experienced any delay.
In addition, they also mentioned using a speaker cleaner, which helps maintain the quality of the speakers and remove unnecessary noise. This can be quite effective in reducing minor problems and improving sound quality.
Your setup is solid, and you’re right — the amp is very unlikely to add any noticeable latency. Since you don’t hear delay through the mixer’s headphone jack, the issue is most likely coming from the audio interface or the overall signal chain before the amp. Hi-fi amps like the Emotiva A100 don’t introduce audible delay. Try checking your interface settings, buffering, or any processing in the chain. The RCA cable won’t cause latency.
