Wondering if any of you are using higher-spec analog input cables to your Sprout instead of generic ones that might come with a portable audio player that has a cheap 3.5mm jack to RCA L/R jacks.
Currently getting by with one (I’m using it with a DAC that has only has analog outs capable to connecting to the Sprout) but wondering if there are others who can recommend something reasonable with audible sonic differences (to you).
(Note: I’d rather this not devolve into a cable debate so please respond if you’re using any upgraded cable.)
Thanks!
dave
